I have a working python test code that gets a token and subscribe and receive RICs.
Using my set of credentials, the code works fine. But testing it with a new test credentials for a prospect client, the token is acquired but the following error is returned after the login json is sent.
What may be causing such error? Thanks
RECEIVED on session1:
"Domain":"Login",
"ID":1,
"Key":{
"Name":"AQIC5wM2LY4Sfcxg5yTArFfqrmVLK4Hx85m3x6boPMMDfM4%3D%40AAJTSQACMjAAAlNLABMzMDkzMDI4MjkxNTU5NDk1MjA5AAJTMQACMzE%3D%23"
"State":{
"Code":"UsageError",
"Data":"Suspect",
"Stream":"Closed",
"Text":"Login Rejected. Watchlist size of 0 for 'WS JSON2' connection is outside of range [1,3000] supported for this ADS fanout tier for this type of connection."
"Type":"Status"
