EikonError: Error code 404
The following code stop working:
import eikon as ek
import pandas as pd
ek.set_app_key('*****')
ek_date = date.today()
brent = ek.get_timeseries(["LCOc1"], start_date = str(ek_date) , end_date = str(ek_date))['CLOSE'].values[0]
Now I have the following error:
EikonError: Error code 404 | Client Error: <!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<title>Error</title>
</head>
<body>
<pre>Cannot POST /api/v1/data</pre>
</body>
</html>
Could you help ?
Thanks,
Antoine
23k 22 9 14
Hello @abedanian,
404 error means "Not found".
As you code was working, many of the common causes of 404 error do not apply in your case, the code is valid, your Eikon user is permissioned for API access, the cause is most likely within environment.
I would first review as per Eikon Data API(Python) Troubleshooting article, and if no obvious discrepancy is found, would next try restarting Eikon and machine running it, as per this previous discussion thread on the same error.
18k 21 12 20
Hi @abedanian
Please also upgrade the Eikon Data API version to 1.1.8 which released around 26th Nov.
