How do extract symbols that fulfil regex criteria in datastream?
For instance, when I type SPXw, I can see a list of options RIC/ Mnemonic in DFO Navigator.
I want this to an output from a python function.
datastream-apiricsdsws-apiderivativesmnemonics
@kenneth.fung
You can DS.SYMBOLLOOKUP with the DataStream.
ds.get_data(tickers="SPXw", fields=["DS.SYMBOLLOOKUP(Count=50)"],  kind=0)
The output is:
To retrieve RICs instead of mnemonics, you need to send another request.
df1 = ds.get_data(tickers="SPXw", fields=["DS.SYMBOLLOOKUP(Count=50)"],  kind=0)
ds.get_data(','.join(df1['Instrument']),fields=["RIC"], kind=0)
DS.SYMBOLLOOKUP(Count=50) // I try to set it as 1000, in anticipation of a result of similar size (1000); but it returns only 25 rows
Plus, DS.SYMBOLLOOKUP(Count=50) seems to return valid RICS/Mnemonic but not the dead ones.
@kenneth.fung
Navigator is the tool that DSWS clients are advised to use.
The symbol lookup was created for quick search, has limited search functionality, and doesn’t cover all content sets.
