Update from Jeff.
The problem is now resolved. It seems to be an issue from the HTTPS proxy on the windows server.
We change it from
HTTPS_PROXY=https://webproxy.XXXX.services:xxx
To:
HTTPS_PROXY=http://webproxy.XXXXXX.services:xxx
Now the test RDP script now connects, and the curl call works:
* Uses proxy env variable https_proxy == 'http://webproxy.XXXX.services:XXX'
* Trying XXXXXX:XXX...
* Connected to webproxy.pln.corp.services (xx.xx.xx.xx) port xx (#0)
* allocate connect buffer!
* Establish HTTP proxy tunnel to api.edp.thomsonreuters.com:443
> CONNECT api.edp.thomsonreuters.com:443 HTTP/1.1
> Host: api.edp.thomsonreuters.com:443
> User-Agent: curl/7.73.0
> Proxy-Connection: Keep-Alive
< HTTP/1.0 200 Connection established
* Proxy replied 200 to CONNECT request
* CONNECT phase completed!
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: D:\curl-7.73.0-win64-mingw\bin\curl-ca-bundle.crt
* CApath: none
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES128-GCM-SHA256
* ALPN, server accepted to use h2
* Server certificate:
* subject: C=US; postalCode=10036; ST=NY; L=New York; street=3 Times Square; O=
Thomson Reuters Inc; OU=EDS Request Response; CN=api.refinitiv.com
* start date: Jul 29 00:00:00 2019 GMT
* expire date: Jul 28 23:59:59 2021 GMT
* subjectAltName: host "api.edp.thomsonreuters.com" matched cert's "api.edp.tho
* issuer: C=GB; ST=Greater Manchester; L=Salford; O=COMODO CA Limited; CN=COMOD
O RSA Organization Validation Secure Server CA
* SSL certificate verify ok.
* Using HTTP2, server supports multi-use
* Connection state changed (HTTP/2 confirmed)
* Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
* Using Stream ID: 1 (easy handle 0x3a68c98af0)
> POST /auth/oauth2/v1/token HTTP/2
> user-agent: curl/7.73.0
> accept: application/json
> content-type: application/x-www-form-urlencoded
> content-length: 105
* Connection state changed (MAX_CONCURRENT_STREAMS == 128)!
* We are completely uploaded and fine
< HTTP/2 400
< date: Tue, 17 Nov 2020 17:55:11 GMT
< content-type: application/json
< content-length: 204
< access-control-allow-origin: *
< server: edsgw
< x-amzn-trace-id: Root=XXXXXXXXXXXXXXXXXXXXXXXXXX
< x-served-by: region=us-east-1; cid=
< x-tr-requestid: XXXXXXXXXXXXXXXXXXXXXXXXXX
{"error":{"id":"XXXXXXXXXXXXXXXXXXXXXXXXX","code":"400","message":"Va
lidation error","status":"Bad Request","errors":[{"key":"grant_type","reason":"M
issing required parameter 'grant_type'"}]}}
* Connection #0 to host webproxy.XXXXXXXXXXXXXXXXXXXX.services left intact
A bit confusing, I understand that you can run the same app from your laptop, but the problem found when running the python codes on the windows server. Is this correct?
curl --data-urlencode "username=<user>&password=<password>&grant_type=password≻ope=trapi" -X POST -H "Accept: application/json" -H "Content-Type: application/x-www-form-urlencoded" -v https://api.edp.thomsonreuters.com/auth/oauth2/v1/token
