Are there any limitation on concurrent access, and how many requests can be submitted?
world-checkscreeningauthenticationscreening-apiapi-limits
There are no software limitations for the Screening Deployed API on neither concurrent access nor concurrent requests.
The limitation of the system is only restricted by the processing capacity of the Screening Deployed server. The API client application should take this into consideration in its design and not overload the server.
