Dear
I have done all the following steps/checks
but I still cannot use the Eikon Api
could you possibly support please ?
Thanks for your time and consideration.
Cheers
Thomas
1. Check Eikon Desktop version
version 4.052 (4.052055)
2. Check Eikon Data APIs version
installed
eikon (1.1.7) - Python package for retrieving Eikon data.
INSTALLED: 1.1.7 (latest)
pretty-eikon (0.0.1) - Package for bulk imports of news and timeseries from Refinitiv Eikon
eikon-docker (0.0.1) - Use the Python Eikon Data API from within a container
wm-dist (1.0.2) - Calculates distances through volume with Eikonal equation
eikonalfm (0.9.5) - solving the (factored) eikonal equation with the Fast Marching method
scikit-traveltime (0.0.7) - Traveltime computation based on the fast marching method for solving the eikonal equation
3. Verify that Eikon Desktop and APIPROXY service is running properly
[2020-11-11 13:18:27.478|1|api-svc|2|DEBUG] SxSServer init OK
[2020-11-11 13:18:28.959|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=1 data={"settingName":"KOBRA.APPLICATION.DESKTOPSXS.ENABLED","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-11-11 13:18:28.972|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=1 data~={"callId":1,"value":"true","action":"ReturnCall"}
[2020-11-11 13:18:28.976|1|api-svc|1|INFO] FT is ready
[2020-11-11 13:18:28.980|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=2 data={"settingName":"{Temporary}RDE_PRODUCT_STRINGID","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-11-11 13:18:28.984|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=2 data~={"callId":2,"value":"NET45,EIKON9.0.52055,SR0,ADF6.20201.2.20","action":"ReturnCall"}
[2020-11-11 13:18:28.986|1|api-svc|3|DEBUG] set User Agent
[2020-11-11 13:18:28.989|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=3 data={"settingName":"{Temporary}KOBRA.APPLICATION.DESKTOPSXS.PO","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-11-11 13:18:28.991|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=4 data={"settingName":"KOBRA.APPLICATION.DESKTOPSXS.HTTP.PORT","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-11-11 13:18:28.993|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=3 data~={"callId":3,"value":"SIDEBYSIDE,APIPROXY","action":"ReturnCall"}
[2020-11-11 13:18:28.996|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=4 data~={"callId":4,"value":"","action":"ReturnCall"}
[2020-11-11 13:18:28.997|1|api-svc|1|INFO] PO: SIDEBYSIDE,APIPROXY
[2020-11-11 13:18:28.998|1|api-svc|3|DEBUG] create SIDEBYSIDE
[2020-11-11 13:18:29.000|1|api-svc|3|DEBUG] create APIPROXY
[2020-11-11 13:18:29.002|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=5 data={"settingName":"KOBRA.APPLICATION.DESKTOPSXS.ENCRYPTION.DISABLED","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-11-11 13:18:29.004|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=6 data={"settingName":"KOBRA.APPLICATION.DESKTOPSXS.BODYPARSER.JSON","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-11-11 13:18:29.005|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=7 data={"settingName":"KOBRA.APPLICATION.DESKTOPSXS.BODYPARSER.URLENCODED","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-11-11 13:18:29.006|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=8 data={"settingName":"RDE_PRODUCT_MSIPRODUCTVERSION","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-11-11 13:18:29.008|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=5 data~={"callId":5,"value":"","action":"ReturnCall"}
[2020-11-11 13:18:29.008|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=6 data~={"callId":6,"value":"","action":"ReturnCall"}
[2020-11-11 13:18:29.009|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=7 data~={"callId":7,"value":"","action":"ReturnCall"}
[2020-11-11 13:18:29.011|1|create-sxs|0|WARN] Failed to get KOBRA.APPLICATION.DESKTOPSXS.BODYPARSER.JSON : Unexpected end of JSON input
[2020-11-11 13:18:29.012|1|create-sxs|0|WARN] Failed to get KOBRA.APPLICATION.DESKTOPSXS.BODYPARSER.URLENCODED : Unexpected end of JSON input
[2020-11-11 13:18:29.018|1|sxs-api|3|DEBUG] [proxy] Add server key kid=clJl3AZjnrpK_wO9wevlpK-FAKz5wzVh61aOpB_B6tI
[2020-11-11 13:18:29.029|1|sxs-api|3|DEBUG] [ws] Create endpoint=/sxs/v1/notifications
[2020-11-11 13:18:29.031|1|sxs-api|3|DEBUG] [ws] Create endpoint=/sxs/s/v1/notifications
[2020-11-11 13:18:29.035|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=8 data~={"callId":8,"value":"4.0.52055","action":"ReturnCall"}
[2020-11-11 13:18:29.052|1|data-api|1|INFO] Request API Proxy port number using channel=/api-proxy/port/request
[2020-11-11 13:18:29.055|1|api-svc|1|INFO] Start server...
[2020-11-11 13:18:29.065|1|api-svc|2|DEBUG] onStarted: 9000
[2020-11-11 13:18:29.066|1|api-svc|1|INFO] Listening to port=9000
[2020-11-11 13:18:30.536|1|data-api|1|INFO] API Proxy is available on port 9060. Start redirecting /api/* requests
[2020-11-11 13:18:38.850|1|sxs-api|3|DEBUG] [event] onMclEvents
Open http://localhost:9000/ping?all on a web browser. (Please note that port 9000 is from step 5.)
{"port":9000,"mode":"eikon4","pid":56712,"hasSecure":true,"startedTime":"Wed Nov 11 2020 14:18:29 GMT+0100 (W. Europe Standard Time)","subApps":[{"path":"/heap"},{"path":"/ping"},{"path":"/sxs","data":{"hasSecure":true,"sxsApps":{}}},{"path":"/api"}]}
df,e = ek.get_data('REUTERS','TR.RIC')
2020-11-11 14:39:55,952 P[113336] [MainThread 58204] Error code 503 | Server Error: <HTML><HEAD><TITLE>Network Error</TITLE></HEAD><BODY><FONT face="Helvetica"><big><strong>
</strong></big><BR><blockquote><TABLE border=0 cellPadding=5 width="80%"><TR><TD align="right">
