Will I need to do a technical certification of an implementation?
world-checkworld-check-one
Hello @Rupert Schilling, Thomson Reuters will need to understand what sort of usage you require, primarily in terms of the number of cases you are looking to create and screen, both through initial and ongoing screening. This is so that we can ensure we have sufficient capacity to support our users, both in the short and long term. "Certification" as it exists in the Screening Online API days will not be needed, as part of the documentation we will give to customers will be an integration flow, so they you do not need to create & submit your own to us for review. We won't need to validate log files, etc, on Pilot either as users will be throttled to a much greater degree on Pilot, so you won't be able to simulate your full anticipated case load within the system.
