Codebook Issues - Code not running/generating graphs
Hello - I'm trying to work through examples in the codebook but they aren't working. Do you have any suggestions why I'm running the code and not getting any results? Further, I'm trying to use codebook to generate histograms,etc; but not receiving anything or just errors. Again, using sample code found in the forum. Thanks.
18k 21 12 20
Hi @jeremy.cahill
I just tested some random sample code from this forum.
And it works fine on Codebook.
I also merge Eikon Data API calls with the sample histogram plot and it also works fine.
Hi @jeremy.cahill
Can you please provide details of which sample code you have tried and/or code snippets so we can try and recreate your specific scenario?
Can you also share the error messages etc you are seeing?
