HI Team, I'm trying to pull data through API but getting an error : HTTPError: <Response [503]>. Can you please confirm if the API is up and running or any other issue from your side
Hi @research5
As an initial step, can you please carry out the diagnostic steps mentioned in the following post with the same error code? Your responses may help my Eikon colleagues identify the cause
Eikon Python API Error code 503
Can you also share the code snippet you are using? - please do not include your AppKey.
