API response 500
Hi // URGENT
i can t have the data eikon python
it worked but now it doesn t
selected=data1['RIC'].tolist()
data = ek.get_timeseries(selected,['CLOSE'],start_date=SD,end_date=ED,interval='monthly')
Traceback (most recent call last):
File "<ipython-input-19-5896114c36e7>", line 9, in <module>
File "C:\ProgramData\Anaconda3\lib\site-packages\eikon\time_series.py", line 160, in get_timeseries
ts_result = eikon.json_requests.send_json_request(TimeSeries_UDF_endpoint, payload, debug=debug)
File "C:\ProgramData\Anaconda3\lib\site-packages\eikon\json_requests.py", line 92, in send_json_request
raise requests.HTTPError(str(response), response=response)
HTTPError: <Response [500]>
4.3k 2 4 5
First actions will be:
  • Stop Eikon Desktop,
  • Clear Eikon cache (see here),
  • then restart Eikon Desktop
Could you also detail useful infos:
  • Python version
  • eikon lib version (I suggest to upgrade to latest 1.1.7 version)
  • Eikon Desktop Version
As you can reproduce, to get more information, you can:
  • activate eikon logs (ek.set_log_level(1) before ek.set_app_key(...)
  • configure Eikon Desktop logs to debug
  • then run your script
And share:
  • python output (without personal info like app key)
  • APIProxy log from from Eikon Desktop log files
    => should be in C:\ProgramData\Thomson Reuters\Eikon Data\Logs\TRD\Eikon.<date>.<pid>\
