Ubiquity permid primary exchange (UI.N)
Trying to find permId via API for this quote:
https://uk.reuters.com/companies/UI.N
Entity search with
"ticker:UI AND mic:XNYS"
doesn't return anything. While I see this permid exists:
https://permid.org/1-21475851712
ricspermid-apientity
@simon.keel
I found that this issue has been resolved.
Could you please confirm it?
@simon.keel
I can replicate the issue. Next, I will contact the Open PermID support team to verify this issue.
Hello @simon.keel
Once searching using more than one identifier, please try to use AND, like this:
Best Regards,
Thanks, issue solved indeed!
