I’m getting a Error Code 500 for something that used to work w/out issue.
My Eikon Desktop is working well and am able to get live quotes/news.
I’ve rebooted and restarted everything so I’m out of ideas…
Before any action, please remove User Detail section (UUID, email, ....) in dump from Help about !
eikon 1.1.7 is available.
Could you upgrade your version ? ("pip install --upgrade eikon")
To Clear Cache, you can start Thomson Reuters \ Thomson Reuters Eikon Tools \ Clear Cache
If something changed in Eikon that causes mismatch, you can run a Clear Cache.
As it that used to work w/out issue, that means you didn't update any python lib (including eikon).
Could you detail following information ?
To get all detail on the error you Could you add following code snippet before get_data() (it'll activate eikon and http logs) ?
import os os.environ["HTTPX_LOG_LEVEL"] = "trace" ek.set_log_level(1)
Then share output response in a text file (remove any reference to application_id value) ?
How do I Clear Cache?
Eikon Desktop Verions is 4.0.52
Eikon lib verion: 1.1.2
Eikon APPS:
* * Refinitiv Eikon * *
* * Version * *
Desktop 4.0.52 (4.0.52055)
* * Connection Status * *
Connection Mode: INTERNET
Heartbeat: OK
Realtime: OK
Data Center: Primary - AMERS2
Deployment Mode: Customer Managed over Internet
Operating System: Microsoft Windows 10 Enterprise
* * Add-ons * *
- Add-ons
- No Add-Ons Installed
* * Apps * *
- APPS (ACTIVE)
ABOUTDIALOG (40.27.18.7)
THOMSONREUTERS.EIKON.ABOUTDIALOG (40.27.18.7)
Installed on 2020-07-01 08:49:14.602
ALERTS (1.0.6.0)
TR.ALERTS (1.0.6.0)
Installed on 2020-03-10 11:41:47.268
ALERTSENGINE (1.0.0.23)
THOMSONREUTERS.EIKON.ALERTSENGINE (1.0.0.23)
Installed on 2020-03-10 11:41:52.381
BOB (3.1.1901.17736)
THOMSONREUTERS.EIKON.BOB (3.1.1901.17736)
Installed on 2020-03-10 11:41:21.618
CHARTS (9.50.0.1)
THOMSONREUTERS.EIKON.CHARTS (9.50.0.1)
Installed on 2020-07-10 14:51:08.083
DESKTOPSXSSVC (1.1.0.95)
THOMSONREUTERS.EIKON.DESKTOPSXSSVC (1.1.0.95)
Installed on 2020-07-06 07:40:12.417
FLOATINGTOOLBAR (4.84.0.53)
THOMSONREUTERS.EIKON.FLOATINGTOOLBAR (4.84.0.53)
Installed on 2020-08-24 09:08:49.156
FXALLSERVICE (1.0.0.14)
THOMSONREUTERS.EIKON.FXALLSERVICE (1.0.0.14)
Installed on 2020-03-10 11:41:46.706
LISTSERVICE (10.0.0.17)
Installed on 2020-03-10 11:42:09.076
NEWS (9.52.0.51)
THOMSONREUTERS.EIKON.NEWS (9.52.0.51)
Installed on 2020-08-24 09:02:38.511
OFFICE.CORE (4.0.52.0)
TR.OFFICE.CORE (4.0.52.0)
Installed on 2020-08-24 09:02:38.545
OFFLINEAPP (1.1.0.148)
THOMSONREUTERS.EIKON.OFFLINEAPP (1.1.0.148)
Installed on 2020-07-01 08:49:09.977
OPSCONSOLE (4.0.17.33)
THOMSONREUTERS.EIKON.OPSCONSOLE (4.0.17.33)
Installed on 2020-07-27 12:32:58.486
PROXY (9.52.0.51)
THOMSONREUTERS.EIKON.PROXY (9.52.0.51)
Installed on 2020-08-24 09:02:38.500
PROXYREGISTRY (4.0.33010.0)
THOMSONREUTERS.EIKON.PROXYREGISTRY (4.0.33010.0)
Installed on 2020-03-10 11:41:25.655
QUICKCHARTS (9.31.14.5000)
THOMSONREUTERS.EIKON.QUICKCHARTS (9.31.14.5000)
Installed on 2020-08-21 11:02:36.688
QUOTE (9.52.0.51)
THOMSONREUTERS.EIKON.QUOTE (9.52.0.51)
Installed on 2020-08-24 09:02:38.492
QUOTELIST (9.52.0.51)
THOMSONREUTERS.EIKON.QUOTELIST (9.52.0.51)
Installed on 2020-08-24 09:02:38.411
REALTIME.PIXLALLPROTOCOLS (9.0.4701.56)
THOMSONREUTERS.REALTIME.PIXLALLPROTOCOLS (9.0.4701.56)
Installed on 2020-03-10 11:41:21.796
REFINITIVHOLDINGS.EIKON.DATAAPIPROXY (1.1.0.12)
Installed on 2020-10-19 08:33:01.959
STARTERCORE (0.0.0.41)
THOMSONREUTERS.EIKON.STARTERCORE (0.0.0.41)
Installed on 2020-03-10 11:41:28.822
STARTERNET (0.0.0.120)
THOMSONREUTERS.EIKON.STARTERNET (0.0.0.120)
Installed on 2020-03-10 11:41:21.752
SUPPORTTOOL (9.1.15.153)
THOMSONREUTERS.EIKON.SUPPORTTOOL (9.1.15.153)
Installed on 2020-03-10 11:48:13.496
SYSTEMTEST (9.51.0.10)
THOMSONREUTERS.EIKON.SYSTEMTEST (9.51.0.10)
Installed on 2020-03-10 11:56:35.214
TAS (9.1.4046.97)
THOMSONREUTERS.EIKON.TAS (9.1.4046.97)
Installed on 2020-03-10 11:41:21.630
THINMONITORMIGRATIONSERVICE (9.52.0.51)
THOMSONREUTERS.EIKON.THINMONITORMIGRATIONSERVICE (9.52.0.51)
Installed on 2020-08-24 09:02:38.560
TRANSACTION.TRADEWEBADAPTER (9.0.14.2)
THOMSONREUTERS.TRANSACTION.TRADEWEBADAPTER (9.0.14.2)
Installed on 2020-07-27 12:27:06.406
TRANSACTION.TRADINGVENUELOGIC (9.0.13.1722)
THOMSONREUTERS.TRANSACTION.TRADINGVENUELOGIC (9.0.13.1722)
Installed on 2020-04-08 16:51:28.603
TSI6 (6.4.2013.44564)
THOMSONREUTERS.EIKON.TSI6 (6.4.2013.44564)
Installed on 2020-03-10 11:41:21.763
UDASERVICE (2.10.13.3)
THOMSONREUTERS.EIKON.UDASERVICE (2.10.13.3)
Installed on 2020-03-10 11:41:36.227
WEBAPPS (9.52.0.51)
THOMSONREUTERS.EIKON.WEBAPPS (9.52.0.51)
Installed on 2020-08-24 09:02:38.519
WEBAPPS_DEV (9.52.0.51)
THOMSONREUTERS.EIKON.WEBAPPS_DEV (9.52.0.51)
Installed on 2020-08-24 09:02:38.527
WEBINTEGRATION (9.52.0.51)
THOMSONREUTERS.EIKON.WEBINTEGRATION (9.52.0.51)
Installed on 2020-08-24 09:02:38.536
- APPS (DOWNLOADED)
- No Apps Downloaded
* * Date Time Settings * *
Time Zone: Eastern Standard Time
Daylight Saving Time (DST): Eastern Daylight Time
Changeover Date:
* * Real-Time Sources * *
- Data Feeds
- No Data Feeds
- Information
- No Information
* * Active Document * *
* * Workspace Size * *
Width and Height Parameters:
Screen Resolution:
Grid Size:
Unit Size:
* * ActiveX Controls * *
* There are no ActiveX Objects in the active document.
* * Design Information * *
Cleared Cache and upgraded but still get same error, but more message. Also checked status of proxy (suggested in another thread) w/ http://localhost:9060/api/status and that gives me it's version number (below). Also attaching new error files w/out removed ids. Need this fixed SOON!!
{"statusCode":"ST_PROXY_READY","version":"2.6.3"}
the error code 500 "self signed certificate in certificate chain" means requests need a corporate certificate.
If your IT can provide this certificate in 'pem' format, could you try following test ?
It doesn't appear that you are doing anything incorrectly from an API perspective. Instead, the intermittent issues may be a result of server overload. The immediate workaround is to try the request with a smaller date range to see if this helps. If you continually encounter this error, the best and most efficient approach is to open a support case with Refinitiv Helpdesk and include the complete details. Your inquiry will be assigned immediately and investigated in a timely manner. These forums do not specialize in server issues.
