Retrieve company and ID name change events
Is there a way to retrieve the Corporate actions ID and name changes via RDP or Eikon API?
i.e. can I programmatically retrieve the info in shown in the screen shots:
AFC.NZ Corporate actions All Historical - Name and ID changes
I know how to get symbol changes with rdp (I do not know how to do this with eikon) but not name changes!
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonrdp-api
18k 21 12 20
Hi @armandnaude
I tried looking for fields carrying the information using Data Item Browser but I could not find them.
I only found this TR.CACorpActEventType field but it does not carry the name change event.
I would suggest that you contact Refinitiv Content Helpdesk at https://my.refinitiv.com/
And ask the content team to provide an Eikon Excel formula if there are any TR fields carrying the information you are looking for.
(assuming there is a field)Once the formula is given, you can easily use the same field/parameter with Eikon Data API.
