Closed / Suspect / Not entitled / 'Access Denied: User req to PE(62)
I am trying to run the example runConsumer450 , but getting error like below.
Services :
Service :
Provider : aws
Transport : tcp
Endpoint : apac-1.pricing.streaming.edp.thomsonreuters.com
Port : 14002
Data Format : rwf
Service :
Provider : aws
Transport : tcp
Endpoint : apac-3.pricing.streaming.edp.thomsonreuters.com
Port : 14002
Data Format : rwf
Service :
Provider : aws
Transport : tcp
Endpoint : apac-2.pricing.streaming.edp.thomsonreuters.com
Port : 14002
Data Format : rwf
Service :
Provider : aws
Transport : tcp
Endpoint : emea-1.pricing.streaming.edp.thomsonreuters.com
Port : 14002
Data Format : rwf
Service :
Provider : aws
Transport : tcp
Endpoint : emea-3.pricing.streaming.edp.thomsonreuters.com
Port : 14002
Data Format : rwf
Service :
Provider : aws
Transport : tcp
Endpoint : emea-2.pricing.streaming.edp.thomsonreuters.com
Port : 14002
Data Format : rwf
Service :
Provider : aws
Transport : tcp
Endpoint : amer-1.pricing.streaming.edp.thomsonreuters.com
Port : 14002
Data Format : rwf
Service :
Provider : aws
Transport : tcp
Endpoint : amer-3.pricing.streaming.edp.thomsonreuters.com
Port : 14002
Data Format : rwf
Service :
Provider : aws
Transport : tcp
Endpoint : amer-2.pricing.streaming.edp.thomsonreuters.com
Port : 14002
Data Format : rwf
Oct 20, 2020 8:15:06 AM com.thomsonreuters.ema.access.ChannelCallbackClient reactorChannelEventCallback
INFO: loggerMsg
Severity: Info
Text: Received ChannelUp event on channel Channel_1
Instance Name Consumer_1_1
Component Version ads3.2.1.L1.linux.tis.rrg 64-bit
loggerMsgEnd
StatusMsg
streamId="5"
domain="MarketPrice Domain"
state="Closed / Suspect / Not entitled / 'Access Denied: User req to PE(62)'"
name="IBM.N"
nameType="1"
serviceId="257"
serviceName="ELEKTRON_DD"
StatusMsgEnd
Oct 20, 2020 8:30:12 AM com.thomsonreuters.ema.access.ChannelDictionary processCallback
WARNING: loggerMsg
ClientName: ChannelDictionary
Severity: Warning
Text: RDMDictionary stream was closed with status message
streamId 3
Reason State: Closed/Suspect/None - text: "Login stream was closed."
loggerMsgEnd
WARNING: loggerMsg
Severity: Warning
streamId 4
loggerMsgEnd
elektronrefinitiv-realtimeelektron-sdkerror-login
23k 22 9 14
Hello @d.gopalasundaram,
The example consumer 450 has hard-coded instrument request for "IBM.N"
IBM.N request requires permissions for PE (permission entity) =62.
Your user is is not permissioned for PE 62.
In code, replace "IBM.N" with an instrument that your user id is permissioned for, rebuild, rerun.
If you do not know which ones, you can try "JPY=", composite currency instrument, and "/IBM.N", delayed IBM.N.
Hi @zoya.farberov
Thanks very much , I am able to run the example runconsumer450 by changing the Item Name. when i am trying to run runConsumer113 getting the below error.
> Task :Ema:Examples:runconsumer113
OmmConsumerConfigImpl::consumerName parameter [Consumer_3] is an non-existent consumer name
@d.gopalasundaram
To run the Consumer113 example, you need to copy the EmaConfig.xml from the 113__MarketPrice__SessionManagement source code directory to the working directory.
The configuration file contains configurations of Consumer_3 used by the example.
        <Consumer>
            <Name value="Consumer_3"/>
            <!-- Channel set to "RSSL_ENCRYPTED"                                                        -->
            <Channel value="Channel_4"/>
            <!-- Dictionary is optional: defaulted to "ChannelDictionary"                                -->
            <Dictionary value="Dictionary_1"/>
            <XmlTraceToStdout value="0"/>
        </Consumer>
        <Channel>
            <Name value="Channel_4"/>
            <ChannelType value="ChannelType::RSSL_ENCRYPTED"/>
            <CompressionType value="CompressionType::None"/>
            <GuaranteedOutputBuffers value="5000"/>
            <!-- EMA discovers a host and a port from EDP-RT service discovery for the specified location
                 when both of them are not set and the session management is enable. -->
            <Location value="us-east"/>
            <EnableSessionManagement value="1"/>
            <!-- ObjectName is optional: defaulted to ""                                                -->
            <ObjectName value=""/>
        </Channel>
For more information, you can follow the Running an EMA example section in this article.
