I would like to have the GDP growth Y/Y expectation for the year end for several countries
I tried with ek.get_timeseries('aITWOGDPR',start_date='2020-12-31',end_date='2020-12-31',interval='yearly') and it worked for a while but then I tried again and I got this message 'EikonError: Error code -1 | aITWOGDPR: TimeSeries request failed |'.
What does this error mean? Do I have just to wait Reuters fix the problem?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythontime-serieseconomic-data
18k 21 12 20
Hi @matteo.avigni
I tested the code for more than 20 times.
The code only works for 2-3 times.
So I think there is a problem with the backend.
I reported this issue on your behalf to Refinitiv Helpdesk.
Ticket no. 09268118 was created and the staff will contact you soon.
Ticket no.09268118 has been closed and the resolution is:
"Please try the request again - sometimes when the server is very busy, some requests fail - if running regularly this is usually remedied by defensive coding in a try-catch structure "
This is in fact Defensive Coding that protects the Head End. An article has been submitted and closing Break Fix Case - Project related updates.
6.7k 8 6 7
@matteo.avigni Please try the request again - sometimes when the server is very busy, some requests fail - if running regularly this is usually remedied by defensive coding in a try-catch structure.
