Dear all,
I try to download time series from python and the examples provided on https://pypi.org/project/eikon/ do not work.
With Excel, I do not have any problems to download series.
How can I solve this issue ?
Dear all,
Hi @thomas.raffinot,
As you're upgraded to more recent version of Eikon, you should find APIProxy file in Eikon Desktop logs, and in this file more detail on what causes the error (don't forget to configure Eikon Desktop logs to debug).
Another user had similar issue, we identified that,Ii addition to network configuration your IT applied to let Eikon Desktop running (EIKON NETWORKING GUIDE), a list of server domain need to be authorized.
More specifically these according to your region:
I join the full list : Eikon API domain address list.txt
We recommend to not expose your app_key.
Could you remove the screenshot (or blur your app_key) ?
Regarding the error, are you running Eikon Desktop on the same machine ?
You can check out the following article on troubleshooting issues with Eikon Data API.
https://developers.refinitiv.com/en/article-catalog/article/eikon-data-api-python-troubleshooting-refinitiv
In addition, could you check if you have following dependency versions that cause issue in current version :
(it supposes that you have eikon 1.1.6.post3)
Your snapshots show "Error: no proxy address identified"
It seems that there is a proxy or a firewall that could block some requests ton Refinitiv servers.
Could you confirm ?
You can get more information if you activate full trace on http request: set environment variable HTTPX_LOG_LEVEL="trace" then run your script.
Check the output, some network error(s) should be highlighted
To investigate deeper, could you activate the log in your script to have a full trace ?
then run your script and check errors in output.
eikon 1.1.7 is available on pypi.
I'm not sure this will fix your problem, but it fixes several issues (especially on dependency versions) and better handles some errors on time series requests.
Could you also check in Eikon logs the file APIProxy.yyyymmdd.hhmmss.txt ?
(it should be in C:\ProgramData\Thomson Reuters\Eikon Data\Logs\TRD\Eikon.202010dd.hhmmss.pxxxx directory)
I updated the package, but the problem is still there: 2020-10-16 16:02:36,419 P[36040] [MainThread 39844] Error: no proxy address identified.
I find a lot of files int the logs, but none starting by APIProxy
Could you activate Eikon log with debug level in Configuration Manager as below ?
Then [Open logs folder], enter in TRD\Eikon.202010dd.hhmmss.pxxxx
You should find APIProxy file as below:
Yes :
Eikon: -eikonpid=37436 -EikonProcessId=25672 -HwndComInterop=0x1 "-manifest=C:\Users\raffinott\AppData\Local\Thomson Reuters\Eikon User\Cache\LibraryCache\9.0.49072_SL1-BIIEEL0__EikonContainer.dll.manifest" "-Context=C:\Users\raffinott\AppData\Local\Thomson Reuters\Eikon User\Cache\LibraryCache\Apps\THOMSONREUTERS.EIKON.DESKTOPSXSSVC\1.1.0.95" /prefetch:1
start node
Arg: C:\Program Files (x86)\Thomson Reuters\Eikon\X\Bin\Eikonbox.exe C:\Users\raffinott\AppData\Local\Thomson Reuters\Eikon User\Cache\LibraryCache\Apps\THOMSONREUTERS.EIKON.DESKTOPSXSSVC\1.1.0.95\index.js -TraceLevel=4
[2020-10-16 16:00:58.298|1|api-svc|1|INFO] PA: false
[2020-10-16 16:00:58.442|1|api-svc|2|DEBUG] Waiting for FT
[2020-10-16 16:01:01.544|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=1 data={"settingName":"KOBRA.APPLICATION.DESKTOPSXS.ENABLED","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:01.771|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=1 data~={"callId":1,"value":"true","action":"ReturnCall"}
[2020-10-16 16:01:01.784|1|api-svc|1|INFO] FT is ready
[2020-10-16 16:01:01.900|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=2 data={"settingName":"{Temporary}RDE_PRODUCT_STRINGID","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:03.450|1|api-svc|0|WARN] [bus] Rpc:sxs:GetSetting Timed out in 1500 ms
[2020-10-16 16:01:03.507|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=3 data={"settingName":"{Temporary}RDE_PRODUCT_STRINGID","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:05.123|1|api-svc|0|WARN] [bus] Rpc:sxs:GetSetting Timed out in 1500 ms
[2020-10-16 16:01:05.237|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=4 data={"settingName":"{Temporary}RDE_PRODUCT_STRINGID","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.203|1|api-svc|2|DEBUG] Gen key successfully
[2020-10-16 16:01:06.212|1|api-svc|2|DEBUG] SxSServer init OK
[2020-10-16 16:01:06.746|1|api-svc|0|WARN] [bus] Rpc:sxs:GetSetting Timed out in 1500 ms
[2020-10-16 16:01:06.754|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=5 data={"settingName":"{Temporary}RDE_PRODUCT_STRINGID","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.765|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=5 data~={"callId":5,"value":"NET45,EIKON9.0.49072,SR0,ADF6.20192.5.10","action":"ReturnCall"}
[2020-10-16 16:01:06.767|1|api-svc|3|DEBUG] set User Agent
[2020-10-16 16:01:06.771|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=6 data={"settingName":"{Temporary}KOBRA.APPLICATION.DESKTOPSXS.PO","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.772|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=7 data={"settingName":"KOBRA.APPLICATION.DESKTOPSXS.HTTP.PORT","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.775|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=6 data~={"callId":6,"value":"SIDEBYSIDE,APIPROXY","action":"ReturnCall"}
[2020-10-16 16:01:06.779|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=7 data~={"callId":7,"value":"","action":"ReturnCall"}
[2020-10-16 16:01:06.781|1|api-svc|1|INFO] PO: SIDEBYSIDE,APIPROXY
[2020-10-16 16:01:06.782|1|api-svc|3|DEBUG] create SIDEBYSIDE
[2020-10-16 16:01:06.785|1|api-svc|3|DEBUG] create APIPROXY
[2020-10-16 16:01:06.791|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=8 data={"settingName":"KOBRA.APPLICATION.DESKTOPSXS.ENCRYPTION.DISABLED","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.792|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=9 data={"settingName":"KOBRA.APPLICATION.DESKTOPSXS.BODYPARSER.JSON","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.794|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=10 data={"settingName":"KOBRA.APPLICATION.DESKTOPSXS.BODYPARSER.URLENCODED","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.796|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=11 data={"settingName":"RDE_PRODUCT_MSIPRODUCTVERSION","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.798|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=8 data~={"callId":8,"value":"","action":"ReturnCall"}
[2020-10-16 16:01:06.799|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=9 data~={"callId":9,"value":"","action":"ReturnCall"}
[2020-10-16 16:01:06.800|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=10 data~={"callId":10,"value":"","action":"ReturnCall"}
[2020-10-16 16:01:06.803|1|create-sxs|0|WARN] Failed to get KOBRA.APPLICATION.DESKTOPSXS.BODYPARSER.JSON : Unexpected end of JSON input
[2020-10-16 16:01:06.805|1|create-sxs|0|WARN] Failed to get KOBRA.APPLICATION.DESKTOPSXS.BODYPARSER.URLENCODED : Unexpected end of JSON input
[2020-10-16 16:01:06.837|1|sxs-api|3|DEBUG] [ws] Create endpoint=/sxs/v1/notifications
[2020-10-16 16:01:06.839|1|sxs-api|3|DEBUG] [ws] Create endpoint=/sxs/s/v1/notifications
[2020-10-16 16:01:06.844|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=11 data~={"callId":11,"value":"4.0.49072","action":"ReturnCall"}
[2020-10-16 16:01:06.874|1|data-api|1|INFO] [ConfigurationManager]Getting configuration ...
[2020-10-16 16:01:06.887|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=12 data={"settingName":"url.apps","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.888|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=13 data={"settingName":"APIPROXY.BACKWARDCOMPATIBILITY.BETA.ENABLED","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.889|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=14 data={"settingName":"common.datacenter.active","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.892|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=15 data={"settingName":"APIPROXY.MINIMALVERSION","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.894|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=16 data={"settingName":"APIPROXY.ENABLED","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.899|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=17 data={"settingName":"APIPROXY.RDP.ENABLED","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.900|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=18 data={"settingName":"APIPROXY.UDF.ENABLED","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.901|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=19 data={"settingName":"APIPROXY.THROTTLING.DAILY.REQUEST.ENABLED","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.902|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=20 data={"settingName":"APIPROXY.THROTTLING.DAILY.REQUEST.MAX","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.903|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=21 data={"settingName":"APIPROXY.THROTTLING.DAILY.VOLUME.ENABLED","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.904|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=22 data={"settingName":"APIPROXY.THROTTLING.DAILY.VOLUME.MAX","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.906|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=23 data={"settingName":"APIPROXY.HANDSHAKE.ENABLED","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.907|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=24 data={"settingName":"APIPROXY.HANDSHAKE.MANDATORY","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.909|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=25 data={"settingName":"APIPROXY.THROTTLING.REQUEST.ENABLED","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.910|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=26 data={"settingName":"APIPROXY.THROTTLING.REQUEST.MAX","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.913|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=27 data={"settingName":"APIPROXY.THROTTLING.REQUEST.PERIOD","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.915|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=28 data={"settingName":"APIPROXY.STREAMING.ENABLED","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.916|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=29 data={"settingName":"APIPROXY.STREAMING.CONNECTION.MAX","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.917|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=30 data={"settingName":"APIPROXY.USAGETRACKING.ENABLED","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.919|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=31 data={"settingName":"APIPROXY.THROTTLING.VOLUME.ENABLED","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.920|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=32 data={"settingName":"APIPROXY.THROTTLING.VOLUME.MAX","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.922|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=33 data={"settingName":"APIPROXY.THROTTLING.VOLUME.PERIOD","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:06.924|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=12 data~={"callId":12,"value":"","action":"ReturnCall"}
[2020-10-16 16:01:06.925|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=13 data~={"callId":13,"value":"","action":"ReturnCall"}
[2020-10-16 16:01:06.927|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=14 data~={"callId":14,"value":"","action":"ReturnCall"}
[2020-10-16 16:01:06.929|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=15 data~={"callId":15,"value":"0.0.0","action":"ReturnCall"}
[2020-10-16 16:01:06.930|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=16 data~={"callId":16,"value":"true","action":"ReturnCall"}
[2020-10-16 16:01:06.931|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=17 data~={"callId":17,"value":"","action":"ReturnCall"}
[2020-10-16 16:01:06.932|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=18 data~={"callId":18,"value":"","action":"ReturnCall"}
[2020-10-16 16:01:06.933|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=19 data~={"callId":19,"value":"true","action":"ReturnCall"}
[2020-10-16 16:01:06.934|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=20 data~={"callId":20,"value":"10000","action":"ReturnCall"}
[2020-10-16 16:01:06.935|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=21 data~={"callId":21,"value":"true","action":"ReturnCall"}
[2020-10-16 16:01:06.935|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=22 data~={"callId":22,"value":"5000000","action":"ReturnCall"}
[2020-10-16 16:01:06.936|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=23 data~={"callId":23,"value":"","action":"ReturnCall"}
[2020-10-16 16:01:06.937|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=24 data~={"callId":24,"value":"","action":"ReturnCall"}
[2020-10-16 16:01:06.938|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=25 data~={"callId":25,"value":"true","action":"ReturnCall"}
[2020-10-16 16:01:06.939|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=26 data~={"callId":26,"value":"5","action":"ReturnCall"}
[2020-10-16 16:01:06.940|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=27 data~={"callId":27,"value":"1","action":"ReturnCall"}
[2020-10-16 16:01:06.940|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=28 data~={"callId":28,"value":"true","action":"ReturnCall"}
[2020-10-16 16:01:06.941|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=29 data~={"callId":29,"value":"10","action":"ReturnCall"}
[2020-10-16 16:01:06.942|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=30 data~={"callId":30,"value":"true","action":"ReturnCall"}
[2020-10-16 16:01:06.943|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=31 data~={"callId":31,"value":"true","action":"ReturnCall"}
[2020-10-16 16:01:06.945|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=32 data~={"callId":32,"value":"50000","action":"ReturnCall"}
[2020-10-16 16:01:06.948|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=33 data~={"callId":33,"value":"60","action":"ReturnCall"}
[2020-10-16 16:01:06.976|1|data-api|1|INFO] [ConfigurationManager]Configuration successfully retrieved.
[2020-10-16 16:01:06.978|1|data-api|3|DEBUG] [ConfigurationManager]{"backwardCompatibilityBetaEnabled":true,"currentVersion":"2.0.0-nightly20200602","currentWebApiVersion":"1.0.0","dataCenter":"","endPointURL":"https://amers1.apps.cp.thomsonreuters.com/Apps/UDF/MSF","handshake":{"enabled":true,"isMandatory":false},"minimalVersion":"0.0.0","minimalVersionRequirementMet":true,"proxyEnabled":true,"rdpAccessEnabled":true,"streaming":{"enabled":true,"maxConnection":10},"throttling":{"dailyRequestCount":{"enabled":true,"max":10000},"dailyVolume":{"enabled":true,"max":5000000},"requestCount":{"enabled":true,"max":5,"period":1},"volume":{"enabled":true,"max":50000,"period":60}},"udfAccessEnabled":true,"usageTrackingEnabled":true}
[2020-10-16 16:01:06.994|1|data-api|3|DEBUG] [UdfController][UdfController::create] Creating UDF controller.
[2020-10-16 16:01:06.995|1|data-api|3|DEBUG] [RdpStreamingDiscoveryController][RdpStreamingDiscoveryController::create] Creating RDP Streaming Discovery controller.
[2020-10-16 16:01:06.997|1|data-api|3|DEBUG] [RdpController][RdpController::create] Creating RDP controller.
[2020-10-16 16:01:06.998|1|data-api|3|DEBUG] [HomeController][HomeController::create] Creating index controller.
[2020-10-16 16:01:06.999|1|data-api|3|DEBUG] [HandshakeController][Handshake::create] Creating handshake controller.
[2020-10-16 16:01:06.999|1|data-api|3|DEBUG] [ApiV1StreamingDiscoveryController][ApiV1StreamingDiscoveryController::create] Creating ApiV1StreamingDiscoveryController controller.
[2020-10-16 16:01:07.000|1|data-api|3|DEBUG] [ApiController][ApiController::create] Creating API controller.
[2020-10-16 16:01:07.002|1|data-api|3|DEBUG] [TracingMiddleware]Creating new request tracing middleware.
[2020-10-16 16:01:07.006|1|data-api|3|DEBUG] [SettingsAggregatorService]Getting value for APIPROXY.THROTTLING.STORE from platform setting service
[2020-10-16 16:01:07.011|1|data-api|3|DEBUG] [TracingMiddleware]Creating new request tracing middleware.
[2020-10-16 16:01:07.014|1|data-api|3|DEBUG] [TracingMiddleware]Creating new request tracing middleware.
[2020-10-16 16:01:07.018|1|data-api|3|DEBUG] [TracingMiddleware]Creating new request tracing middleware.
[2020-10-16 16:01:07.023|1|data-api|3|DEBUG] [ABFT][ABFT] Applying anti-bruteforce throttling
[2020-10-16 16:01:07.040|1|data-api|1|INFO] [Throttling][RBT] Request-count based throttling has been enabled by configuration.
[2020-10-16 16:01:07.041|1|data-api|3|DEBUG] [Throttling][RBT] Applying request-count limits - 5 request(s) per 1 second(s)
[2020-10-16 16:01:07.043|1|data-api|1|INFO] [Throttling][VBT] Volume-based throttling has been enabled by configuration.
[2020-10-16 16:01:07.044|1|data-api|3|DEBUG] [Throttling][VBT] Applying volume limits - 50000 KB per 60 second(s)
[2020-10-16 16:01:07.048|1|data-api|1|INFO] [WebSocketServer]Creating new WebSocket server instance
[2020-10-16 16:01:07.050|1|data-api|3|DEBUG] [WebSocketServer]WebSocket path is /api/rdp/streaming/pricing/v1/WebSocket. Max simultaneous connections: 10
[2020-10-16 16:01:07.052|1|data-api|1|INFO] [ApiV1WebSocketServerProvider]Creating new WebSocket server instance
[2020-10-16 16:01:07.053|1|data-api|3|DEBUG] [ApiV1WebSocketServerProvider]WebSocket path is /api/v1/data/streaming/pricing/WebSocket. Max simultaneous connections: 10
[2020-10-16 16:01:07.055|1|api-svc|1|INFO] Start server...
[2020-10-16 16:01:07.067|1|api-svc|0|WARN] Server listen -> listen EACCES 127.0.0.1:9000
[2020-10-16 16:01:07.070|1|api-svc|2|DEBUG] [bus] channel=/desktopsxs name=sxs:GetSetting callId=34 data={"settingName":"APIPROXY.THROTTLING.STORE","provider":"Configuration","isVersioning":false,"action":"GetSetting"}
[2020-10-16 16:01:07.073|1|api-svc|2|DEBUG] onStarted: 9001
[2020-10-16 16:01:07.076|1|api-svc|2|DEBUG] [bus] onCallback name=sxs:GetSetting callId=34 data~={"callId":34,"value":"{\"dailyRequest\":\"[[\\\"127.0.0.1\\\",[[1601942400000,1]]]]\",\"dailyVolume\":\"[[\\\"127.0.0.1\\\",[[1601942400000,17994]]]]\"}","action":"ReturnCall"}
[2020-10-16 16:01:07.077|1|data-api|3|DEBUG] [SettingsAggregatorService]Got value '{"dailyRequest":"[[\"127.0.0.1\",[[1601942400000,1]]]]","dailyVolume":"[[\"127.0.0.1\",[[1601942400000,17994]]]]"}', trying to parse ...
[2020-10-16 16:01:07.079|1|data-api|3|DEBUG] [SettingsAggregatorService]Parsing succeeded !
[2020-10-16 16:01:07.080|1|data-api|1|INFO] [Throttling][DRBT] Daily request-count based throttling has been enabled by configuration.
[2020-10-16 16:01:07.081|1|data-api|3|DEBUG] [Throttling][DRBT] Applying daily request-count limits - 10000 request(s) per day
[2020-10-16 16:01:07.084|1|data-api|1|INFO] [Throttling][DVBT] Daily volume-based throttling has been enabled by configuration.
[2020-10-16 16:01:07.085|1|data-api|3|DEBUG] [Throttling][DVBT] Applying daily volume-based limits - 5000000 KB per day
[2020-10-16 16:01:07.089|1|data-api|1|INFO] Write port file
[2020-10-16 16:01:07.091|1|api-svc|1|INFO] Listening to port=9001
[2020-10-16 16:01:07.096|1|api-svc|0|WARN] Error: messenger not found.
[2020-10-16 16:01:07.099|1|sxs-api|3|DEBUG] [ws] Create endpoint=/sxs/v1/services/messenger
According to SxS log, you have Eikon 4.0.49072
Could you confirm this Eikon version ?
If it's the case, that could explain why API Proxy is not found by python api.
There were 3 versions since 4.0.49 (released on Aug Th 2019): 4.0.51 and 4.0.52 were released on Jun 22th and Aug 14th 2020
I suggest to contact Refinitiv to upgrade your Eikon.
My It has updated my Eikon version but it still does not work at all
@pierre.faurel
