sorry I can't write English.
sample code:
import eikon as ek ek.set_app_key('cxxxxx')
eikon.eikonError.EikonError: Error code -1 | Port number was not identified. Check if Eikon Desktop or Eikon API Proxy is running.
http://localhost:9000/ping?all
{"port":9000,"mode":"eikon4","pid":5352,"hasSecure":true,"startedTime":"Thu Oct 08 2020 00:46:08 GMT+0900 (대한민국 표준시)","subApps":[{"path":"/heap"},{"path":"/ping"},{"path":"/sxs","data":{"hasSecure":true,"sxsApps":{}}},{ "path":"/api"},{"path":"/sxs/v1/services/messenger"}]}
checkeikondataapi.ps1
OS : window 10
Python version : 3.8.6 32bit
IDE : Pycharm
eikin lib version : 1.1.6.post3,
httpx version : 0.15.5
Eikon Desktop Info
eikon-desktop-info.txt
test ---
eikon lib version
1.1.2 work.
1.1.4 not work. Port number was not identified
1.1.5 not work. Port number was not identified
1.1.6 not work. Port number was not identified
thank you.
