How can I run the Ratings Transition Matrix given I copied the code in Documentation ?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythoncredit-ratings
Thanks for your reply. Infact, I solved this issue already. I copy the codes to run in Codebook, but it does not work, then I used Spyder to run these codes, it worked.
Thanks very much,
Khang
18k 21 12 20
Hi @khangdiep
Can you share the documentation and sample code you are trying to run?
