RFA RSSL OMMConsumer gets RSSL_RET_INCOMPLETE_DATA in class MapReadIterator in method forth() exception when processing large RDM Symbol List . Consumer RFA API has does not define numInputBuffers parameter, assuming default 5.
1. What is recommended size of fragment for OMM provider, publishing large symbol list refresh to split into multiple fragments, considering consumer uses default numInputBuffers.
2. What is exact meaning of "input buffer size" in RFA Configuration guide? The guide mentions [numInputBuffers * input buffer size bytes] is a number of bytes for a single read socket call.
Thank you
