Is it possible to retrieve via Eikon Data API using Python in one go? Similar to the Eikon Excel =@TR("EUROIS=ICAP";"";"CH=Fd RH=IN";N4)
client is interested in accessing EUROIS=ICAP using Eikon Data API. In the Quote in Eikon it is a Chain display however via Eikon Data API
df, err = ek.get_data(
instruments = ['EUROIS=ICAP'],
fields = ['PRIMACT_1']
display(df) doesn't return the list of RICs.
Thanks for your help
6.7k 8 6 7
@silke.haupt1 I can't find that as a chain - the quote display is simply a list of instruments rather than a chain but if you hover over each tenor then you can get the instruments eg:
SW EUREONSW=ICAP
2W EUREON2W=ICAP
30Y EUREON30Y=ICAP
These are fixed then you can put those into get_data call. Note: you can also select different broker quotes (in this case you wanted ICAP but there are others of course)
I hope this can help
