EikonError: Error code 401 | Client Error: Data API Proxy requires authentication.
Hi guys, I can see it is a popular question but most answers are around restarting machine. I have tried 5 times today. Are there any other things I can do? Do I need to re-install Eikon? Also I have got 3 Eikon logins and only one of them is permitted for Eikon API. Do I need to clean Eikon cache?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonerror-401
Hi Pierre
Many thanks for your response. Note wrt Eikon version. The issue actually resolved this morning for me without the steps you mentioned above. Very useful though for future reference to understand where the issue might be should it occur again! Hopefully it wont ;)
4.3k 2 4 5
Could you detail :
  • Eikon Desktop version ?
  • eikon lib version ?
Hi Pierre
Eikon 4.0.53
eikon lib latest one (Sep 25)
4.3k 2 4 5
OK, understood, you have a version that isn't yet released (4.0.53 should be available soon in pre-released for external users).
An issue was detected in Eikon 4.0.53 that disables the connection for python API.
A fix is ready but can't be released immediatly.
In the meantime, there is a 2 workarounds:
  1. copy C:\Program Files (x86)\Thomson Reuters\Eikon\[x y z]\Config\SSOConfig.xml
    to C:\ProgramData\Thomson Reuters\Eikon Data\[x y z]\ConfigMachine
  2. downgrade to Eikon 4.0.52 (but the above should fix the issue).
