With regards to Refinitiv Real-Time SDK - Linux Edition Program Version: 1.5.1.L1 I which is compatible for RedHat and CentOS, would you know whether also works with Fedora workstation?
elektronrefinitiv-realtimeelektron-sdkrefinitiv-realtime-sdkfedora
Hi @davide.bray
In theory, it should work with Fedora versions - but it has not been tested with or qualified with Fedora either.
If any bugs were discovered on Fedora they would have to be reproducible on a supported OS in order to obtain a fix.
