Does record matching support website?
For /match the default example you show suggests that `website` is supported, though none of the examples I can find in the documentation actually show it being used. Is it supported, if so what is the format as any test I try with a website fails?
LocalID,Standard Identifier,Name,Country,Street,City,PostalCode,State,Website 1,RIC:AAPL.O|Ticker:AAPL,Apple,US,"Apple Campus, 1 Infinite Loop",Cupertino,95014,California,
For /match/file where can you find the example csv format? The "see an example here" link takes you to a page that doesn't have the csv (that I can tell).
intelligent-tagging-apipermid-apiopen-permid-apitemplatesupport
For /match, you can find templates here. There are three templates: Organization, Instrument, and Quote.
For /match/file, exampleRM.csv is in the Open PermID - Record Matching - Tutorial.
Hi @travis,
Thank you for the question.
For Match API you can use the following example:
"LocalID","Name","Website"
1,Microsoft,
2,Microsoft,http://www.microsoft.com
You will see that while the first record will result in a match score of 92%, adding the website will bring it higher to 96%.
Please note that matching by website only is currently not supported, however as we can see in the example above, adding a website can increase the match score.
For the CSV (matchfile), you can use the same website as above.
For Apple you can use the following website: http://www.apple.com/
Regards,
Gilad, the permid.org team
