Port number was not identified. httpx api has changed.
I've upgraded to the latest version of eikon 1.1.6.post2 in order to solve a separate issue. However, I get the error Port number was not identified.
After doing some digging I've narrowed it to the check_port method:
In [1]:
APP_KEY = "..."
In [2]:
import logging
import eikon as ek
logger = logging.getLogger("pyeikon")
logger.setLevel(5)
desktop_session = ek.streaming_session.desktop_session.DesktopSession(APP_KEY)
await desktop_session.check_port(9000)
desktop_session._check_port_result
2020-09-24 15:02:27,834 P[23284] [MainThread 1104] Send GET request to http://localhost:9000/api/status to detect API Proxy...
2020-09-24 15:02:27,840 P[23284] [MainThread 1104] Error on checking port 9000 : AttributeError("'Request' object has no attribute 'prepare'",)
Calling http_request_async
_http_request <Request('GET', 'http://localhost:9000/api/status')>
['__class__', '__delattr__', '__dict__', '__dir__', '__doc__', '__eq__', '__format__', '__ge__', '__getattribute__', '__gt__', '__hash__', '__init__', '__init_subclass__', '__le__', '__lt__', '__module__', '__ne__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '__weakref__', '_prepare', 'aread', 'content', 'headers', 'method', 'read', 'stream', 'url']
Out[2]:
False
Within the eikon package I've also printed the _http_request object on line 630 of eikon.streaming_session.session.Session.
_http_request is an instance of httpx.Request. However, the api for this has changed and the prepare method has been made private as _prepare.
Note that the call to _http_request.prepare() will now throw an attribute error (as I am getting). I imagine that the devs will want to take a look and make changes as required (or lock the httpx dependency to a version that worked).
Thanks, Simon.
4.3k 2 4 5
You're right, we detected yesterday a breaking change in httpx and we'll published soon a fix.
In the meantime, you can downgrade httpx to 0.14.2 as a workaround (pip install httpx==0.14.2)
