Nasdaq Nordic via Eikon Data API error
Dear all,
a customer reported an issue with our Eikon Data API. He occasionally get following error message:
{'columnHeadersCount': 1,
'data': [['GB00BKZZ4R47.ST', None, None, None, None]],
'error': [{'code': 251658243,
'col': 1,
'message': "'Access Denied' for the instrument 'GB00BKZZ4R47.ST'",
This error occurs every once in a while and only on exchange "Nasdaq Nordics". Despite the "Access Denied" message he can use the very same RIC and get data in Eikon without any issues... What might be the potential issue with this one if not the permissioning ?
Many thanks,
Almir
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonauthentication
@Almir Purisic
'Access Denied' message comes from Refinitiv backend. I suggest you open a support case with Refinitiv Helpdesk to have the issue investigated. It would be most helpful to have the HTTP request returning this message captured using Fiddler. Or at least note the date and time when the issue occurred and the API call (including the field names requested) that returned the error. User's Eikon login or UUID would also be required to examine backend logs and find those failed requests.
Hi Alex, thank you for the advice. I will contact the client and ask him to provide us the things mentioned so backend can take a look into it. Many thanks! Almir
I think the issue you experiencing is the fact that that instrument is a Leveraged Certificate/ETP (Exchange Traded Product) and the Eikon Data API is currently predominantly focused to equities and as far as I know does not provide access to ETP/ETN
See:
http://www.nasdaqomxnordic.com/etp/leverage-certificates/leverage-certificate-historical?Instrument=SSE192108
