I use dex2 manager in COM API to request ISIN and SEDOL fields:
Sample code:
HRESULT l_hr = m_RData->put_InstrumentIDList(CComVariant(a_InstrumentIDList)); if (l_hr == S_OK) { l_hr = m_RData->put_FieldList(CComVariant(a_FieldList)); if (l_hr == S_OK) { l_hr = m_RData->put_RequestParam(CComVariant(a_RequestParam)); if (l_hr == S_OK) { l_hr = m_RData->put_DisplayParam(CComVariant(a_DisplayParam)); } else { wstring w_request(a_RequestParam); string error("[EikonComDex2] Couldn't set the RequestParam: " + string(w_request.begin(), w_request.end())); m_logger->Log(error, DCLogger::DC_LOG_LEVEL_ERROR); DataCollectorHelper::CoutLog(error, DC_RED); } } else { wstring w_fields(a_FieldList); string error("[EikonComDex2] Couldn't set the FieldList: " + string(w_fields.begin(), w_fields.end())); m_logger->Log(error, DCLogger::DC_LOG_LEVEL_ERROR); DataCollectorHelper::CoutLog(error, DC_RED); } }
a_InstrumentIDList : 1 RIC or comma separated RICs
a_FieldList : "TR.ISIN,TR.SEDOL"
a_DisplayParam: "RH:In"
If instrument list is "FROG.OQ", I receive:
'FROG.OQ','IL0011684185','BMX6JW3'
If instrument list is ",FROG.OQ" , I receive:
'FROG.OQ',IL0011684185,'BMX6JW3' 'FROG.OQ','null','BMX6JW3'
If instrument list is ",,,FROG.OQ" , I receive:
RIC field is invalid RIC field is invalid 'FROG.OQ',IL0011684185,'BMX6JW3' 'FROG.OQ','null','BMX6JW3'
This is reproducible. Could you check if this is a bug?
Second case:
If instrument list is "ACET.OQ", I receive:
'ACET.OQ','US0070021086','BMC5RV6' 'ACET.OQ','US0070021086',null
