Did you manage to request the source directory as per your previous query?
If you did then you will note that part of the information received contains status i.e. the Service State and if it is Accepting Requests
MAP MAP_ENTRY (Action.ADD) : flags: Key: IDN_RDF Value: FILTER_LIST flags: FILTER_ENTRY 1 (Action.SET) : flags: ELEMENT_LIST ELEMENT_ENTRY Name: IDN_RDF ELEMENT_ENTRY Vendor: Reuters ELEMENT_ENTRY Capabilities: ARRAY ARRAY_ENTRY: 5 ARRAY_ENTRY: 6 .... .... FILTER_ENTRY 2 (Action.SET) : flags: ELEMENT_LIST ELEMENT_ENTRY ServiceState: 1 ELEMENT_ENTRY AcceptingRequests: 1 MAP_ENTRY (Action.ADD) : flags: Key: ELEKTRON_DD Value: FILTER_LIST flags: FILTER_ENTRY 1 (Action.SET) : flags: ELEMENT_LIST ELEMENT_ENTRY Name: ELEKTRON_DD ELEMENT_ENTRY Vendor: Reuters ELEMENT_ENTRY Capabilities: ARRAY ARRAY_ENTRY: 5 ARRAY_ENTRY: 6 ARRAY_ENTRY: 7 .... .... FILTER_ENTRY 2 (Action.SET) : flags: ELEMENT_LIST ELEMENT_ENTRY ServiceState: 1 ELEMENT_ENTRY AcceptingRequests: 1
In the above extract of the Source Directory you can see two services; IDN_RDF and ELEKTRON_DD and both ave ServiceState : 1 (UP) and AcceptingRequests : 1 (Yes)
You can get more details in the RDMUsageGuide.pdf file that comes with your RFA developer kit.
The other thing to note is that provided your source directory request is a streaming one (i.e. not a Snapshot request) then you would receive updates to the directory as and when a service state changes e.g. if a service goes down at later point in time..
Hi @alokreturns. It seems like this reply above is satisfactory in resolving your query, so we are going to click the 'Accept' this answer on your behalf.
Regards,
AHS
