Can EstGuidMeanAtDate return a single number?
This is a question about Excel API. When I type the formula below into a cell in Excel,
=TR("WMT","TR.EstGuidMeanAtDate.value", "GuidEstMeasure=EPS RollPeriods=True Period=FY1 SDate=2012-01-05")
It returns a vector:
4.42948
4.45533
4.49863
Why does it return a series of number? I specify EPS guidance for FY1 as of 2020-01-05, so I expect only one number. Could someone help me get the only latest EPS guidance as of a date that I select?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythoneikon-com-api
6.7k 8 6 7
@iwasaki Hi i am using the python API but its hitting the same service - I get the same thing 3 data values - see below:
So I can replicate the response - I think you should speak to the content team by opening a content query as they are best placed to handle what the output means.
You can do this by going to the helios menu (next to search bar) --> contact us.
I hope this can help.
6.7k 8 6 7
Hi @iwasaki maybe because your start date is 2012-01-05 - so either change that to 2020. Or can I suggest you use the following field TR.EPSMean(Period=FY1).
=TR("WMT","TR.EPSMean(Period=FY1)")
Thank you for quick response. What I want is TR.EstGuidMeanAtDate, which is a company guidance and different from consensus estimate TR.EPSMean. Moreover, I specifically want the FY1 guidance number as of 2012-01-05.
