Now it works. Could it be, someone restarted the API server?
Hi Sven glad to know it is now working on your end. I have monitored the instrument as well but has not recorded any issue. Not just sure with the API server itself.
The following code can help you to reproduce the error messages
import eikon as ek from datetime import date, datetime, timedelta import dateutil.relativedelta as dateutil from sqlalchemy import create_engine from sqlalchemy.sql import select import numpy import time ek.set_app_key('YourAppKey') retrials = 0; starting = datetime.now() print('Gestartet: ' + starting.strftime("%H:%M:%S")) # input Parameter ANFANG table_name = "dbName" table_mode = "replace" max_retries = 50 rrg_index = [ [".IXIC", ".5SP10", ".5SP15", ".5SP20", ".5SP25", ".5SP30", ".5SP35", ".5SP40", ".5SP45", ".5SP50", ".5SP55", ".5SP60"], [".SPX", ".5SP10", ".5SP15", ".5SP20", ".5SP25", ".5SP30", ".5SP35", ".5SP40", ".5SP45", ".5SP50", ".5SP55", ".5SP60"], [".E1DOW", ".E1TEC", ".E1IDU", ".E1NCY", ".E1FIN", ".E1TLS", ".E1UTI", ".E1HCR", ".E1ENE", ".E1CYC", ".E1BSC"] ] # input Parameter ENDE print('++++++++++++++++++++++++++++++++++++++++++++++++++++++++') print('Tabelle: ' + table_name) print('Modus: ' + table_mode) print('++++++++++++++++++++++++++++++++++++++++++++++++++++++++') try: retrials_1 = 0 con = engine.connect() end = datetime.now() - timedelta(days=1) start = end - timedelta(weeks=40) start_string = start.strftime("%Y-%m-%d") end_string = end.strftime("%Y-%m-%d") print(start_string) print(end_string) for row in rrg_index: main_index = row[0] print(main_index) i = 0 while (i < len(row)): aRIC = row[i] print("Load " + aRIC) time.sleep(2); try: req = ek.get_timeseries(aRIC, start_date=start_string , end_date=end_string, interval='weekly', corax='adjusted') print('Ergänzung um Datum und Index und speichern.') # do some database work table_mode = "append" i = i + 1 retrials_1 = 0 except Exception as anExc: print('Exception:') print(anExc) print('### RIC ###') print(aRIC) if retrials_1 > max_retries: i = i + 1 print("ACHTUNG:", aRIC) retrials_1 = retrials_1 + 1 time.sleep(3); retrials = 0 except Exception as anExc: print('Exception:') print(anExc) print('Beendet.')
Hi Sven adding my comment here if this may help on the issue. Upon further investigation. "Server returns error and Insufficient data" might be related to Eikon data limitation when retrieving time series data. For <.5SP20>, please note that for retrieving intraday data (like for end-of-day RICs) it is only limited to 3 months.
