Backend Error 400
Getting a lot of error 400 today:
2020-09-15 18:16:30,790 -- pyeikon -- DEBUG -- HTTP Response code: 200
2020-09-15 18:16:30,790 -- pyeikon -- DEBUG -- HTTP Response: {"ErrorCode":400,"ErrorMessage":"Backend error. 400 Bad Request"}
2020-09-15 18:16:30,790 -- pyeikon -- ERROR -- Backend error. 400 Bad Request
2020-09-15 18:16:30,867 -- pyeikon -- DEBUG -- Request:{'Entity': {'E': 'DataGrid_StandardAsync', 'W': {'requests': [{'instruments': ['0#IND:'], 'fields': [{'name': 'RECORDTYPE'}]}]}}}
2020-09-15 18:17:45,647 -- pyeikon -- DEBUG -- Request:{'Entity': {'E': 'DataGrid_StandardAsync', 'W': {'requests': [{'instruments': ['0#DIJ:'], 'fields': [{'name': 'RECORDTYPE'}]}]}}}
2020-09-15 18:18:04,230 -- pyeikon -- DEBUG -- HTTP Response code: 200
2020-09-15 18:18:04,230 -- pyeikon -- DEBUG -- HTTP Response: {"ErrorCode":400,"ErrorMessage":"Backend error. 400 Bad Request"}
2020-09-15 18:18:04,230 -- pyeikon -- ERROR -- Backend error. 400 Bad Request
2020-09-15 18:19:19,123 -- pyeikon -- DEBUG -- Request:{'Entity': {'E': 'DataGrid_StandardAsync', 'W': {'requests': [{'instruments': ['0#DOL:'], 'fields': [{'name': 'RECORDTYPE'}]}]}}}
2020-09-15 18:19:37,785 -- pyeikon -- DEBUG -- HTTP Response code: 200
2020-09-15 18:19:37,785 -- pyeikon -- DEBUG -- HTTP Response: {"ErrorCode":400,"ErrorMessage":"Backend error. 400 Bad Request"}
2020-09-15 18:19:37,786 -- pyeikon -- ERROR -- Backend error. 400 Bad Request
Also tried 1.5h ago with the same errors.
Is there something wrong with backend server now?
Problem solved magically by restarting Eikon twice.
18k 21 12 20
Hi @igorg
I just tried to test the API calls for 100 times and it works fine.
import time
for x in range(100):
    try:
        df,e = ek.get_data('0#IND:','RECORDTYPE')
        print(x,':',df.head(1))
        time.sleep(1)
    except EikonError:
        print(EikonError)
        continue
Output:
0 :   Instrument  RECORDTYPE
0     INDV20         114
1 :   Instrument  RECORDTYPE
0     INDV20         114
2 :   Instrument  RECORDTYPE
0     INDV20         114
3 :   Instrument  RECORDTYPE
0     INDV20         114
96 :   Instrument  RECORDTYPE
0     INDV20         114
97 :   Instrument  RECORDTYPE
0     INDV20         114
98 :   Instrument  RECORDTYPE
0     INDV20         114
99 :   Instrument  RECORDTYPE
0     INDV20         114
If you still seeing the error, please submit a ticket to Refinitiv Helpdesk at my.refinitiv.com/
pyeikon.20200915.18-10-52.log.txtpyeikon.20200915.16-43-09.log.txt
I'm attaching 2 log files generated by Eikon Python API from today. Please check how many errors they have.
Hi @igorg
The moderator in this forum can provide guidance on the sample code e.g. how to use the API, what is the sample code on the API, etc...
For product support or technical troubleshooting, you have to open a ticket to Refinitiv Helpdesk.
