I'm trying to remove false positive when calling the endpoint cases/${caseSystemId}/results
However we got an 404 error
We're using the version v1
Does anyone encounter the same problem ?
Thank you
Thank you
@Prabhjyot.Mandla
Hello, thank your for your answer. Yes I'm using the case-system-id of the same environment.
I perform some get request to cases/screeningRequest right before and it works quite well!
So not sure why it would work for cases/screeningRequest but not for cases/$CaseSystemId/results
I'm not sure how to the same via UI but I've never encounter any problem before
Can you please share the request and response headers of the failed api call, so we may look into it?
Hello @blafon,
Could you please supply the additional info as requested by @Prabhjyot.Mandla so that we can better understand and try to help with your question?
