Time series using ek.get_data
I am trying to retrieve mid price for the following ticker using the below
df = ek.get_data('EURCBS3M=ICAP', ['TR.ASKPRICE.Date', 'TR.ASKPRICE','TR.BIDPRICE'], parameters={'SDate':'2017-08-01', 'EDate':'2020-09-14'})
I do not believe Mid is available so i retreive Bid and Ask
So i am first ading new column for Mid
df['Mid'] = df['TR.ASKPRICE'] + df['TR.BIDPRICE']
but coming back with error :
TypeError: tuple indices must be integers or slices, not str
Can someone explain what is going wrong here - whey it does not recognise above as dataframe?
Also by retrieving in this manner is the Date column recognised as an actual date?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythontime-series
@paul67
To answer your question about the Date column, get_data method returns date and time stamps as ISO 8601 strings. To convert these strings to datetime type use pandas.to_datetime method.
Hi @paul67
The return value from the get_data is a tuple rather than a dataframe as it returns the dataframe and any errors
So, the following works for me
df,err = ek.get_data('EURCBS3M=ICAP', ['TR.ASKPRICE.Date', 'TR.ASKPRICE','TR.BIDPRICE'], parameters={'SDate':'2017-08-01', 'EDate':'2020-09-14'})
df['Mid'] = (df['Ask Price'] + df['Bid Price'])/2
Can you also expand on your question about the date Column - I don't fully understand the question?
