Response object has no attribute reason
Hi. I'm using a new reuters setup on a different pc, however whenever I run the following code
I get the error AttributeError: 'Response' object has no attribute 'reason'
import eikon as ek
ek.set_app_key('***')
tmp,err = ek.get_timeseries(['AAPL.OQ'],start_date='2018-08-03', end_date='2018-09-03', interval='daily')
Some items to note: I am using windows 10 & anaconda, I have uninstalled anaconda and re-installed the latest version, I have used this app key many times on another pc.
I receive this error whenever I use the version 1.1.6.post1
I tried reverting back to version 1.1.5 (not that Ive used this before) however I keep getting a different error "API Proxy" not available. I've restarted my pc and the kernel several times.
Running python directly (without anaconda) results in the same error.
I have also tried using this with a newly generated app key.
Any help would be appreciated. Thank you
I seem to have gotten it working. Tried a few things but maybe had the biggest influence was
I upgraded from python 3.7.9 to python version 3.8.3
Same response with any query I run
df, err = ek.get_data(['GOOG.O','MSFT.O'],['CLOSE'])
Traceback (most recent call last):
File "<ipython-input-14-10a7310817f7>", line 1, in <module>
File "C:\ProgramData\Anaconda3\lib\site-packages\eikon\data_grid.py", line 190, in get_data
result = eikon.json_requests.send_json_request(_endpoint, payload, debug=debug)
File "C:\ProgramData\Anaconda3\lib\site-packages\eikon\json_requests.py", line 131, in send_json_request
_raise_for_status(response)
File "C:\ProgramData\Anaconda3\lib\site-packages\eikon\json_requests.py", line 227, in _raise_for_status
if isinstance(response.reason, bytes):
Update: I have also installed version 1.1.2 now which brings up (again)
EikonError: Error code 503 | Server Error: API Proxy is not available
trying http://localhost:9000/ping?all brings up a result with {"path":"/api"}
If I go to the ".portInUse" file it used to say 9060, Ive changed it to 9000, neither work
4.3k 2 4 5
AttributeError: 'Response' object has no attribute 'reason' was fixed in 1.1.6.post2
all functions were running well until yesterday, now I get the same error code
My python version is 3.8.5
eikon version is 1.1.6
and httpx is 0.14.2
I was trying to run the following code:
df = ek.get_news_headlines('R:.SPX AND Language:LEN', date_from='2021-02-13T09:00:00', date_to='2021-02-18T18:00:00', count = 100)
Would be great if anyone could share some advice on this error!
