2 days ago, my eikon through python stopped working on my machine with no apparent reason, showing only the error message: Error code 500 | Server Error: Internal Server Error - {"code":500,"message":"getaddrinfo ENOTFOUND emea1.apps.cp.thomsonreuters.com emea1.apps.cp.thomsonreuters.com:443","statusMessage":"Internal Server Error"}; using python 3.6, eikon python package 1.1.4, eikon desktop 4.0.52
Then I could check that the APIPROXY is running properly with curl:
C:\Windows\system32>curl http://localhost:9000/ping?all
{"port":9000,"mode":"eikon4","pid":15688,"hasSecure":true,"startedTime":"Thu Sep 10 2020 15:53:24 GMT+0200 (W. Europe Summer Time)","subApps":[{"path":"/heap"},{"path":"/ping"},{"path":"/sxs","data":{"hasSecure":true,"sxsApps":{}}},{"path":"/api"},{"path":"/sxs/v1/services/messenger"}]}
I also tried the handshake test that is proposed in the link you sent, but that does not look good.
C:\Windows\system32>curl http://localhost:9000/api/handshake
Temporary Redirect. Redirecting to http://localhost:9060/api/handshake
C:\Windows\system32>curl http://localhost:9060/api/handshake
{"code":404,"message":"Not Found","statusMessage":"Not Found"}
from the APIPROXY logs:
[2020-09-10 13:53:24.141|1|api-svc|1|INFO] PO: SIDEBYSIDE,APIPROXY
[2020-09-10 13:53:24.149|1|api-svc|3|DEBUG] create SIDEBYSIDE
[2020-09-10 13:53:24.157|1|api-svc|3|DEBUG] create APIPROXY
[2020-09-10 13:53:24.317|1|api-svc|1|INFO] Start server...
[2020-09-10 13:53:24.339|1|api-svc|2|DEBUG] onStarted: 9000
[2020-09-10 13:53:24.351|1|api-svc|1|INFO] Listening to port=9000
[2020-09-10 13:53:24.361|1|data-api|1|INFO] API Proxy is available on port 9060. Start redirecting /api/* requests
[2020-09-10 13:53:24.369|1|api-svc|0|WARN] Error: messenger not found.
