How can I login to administration / management panel?
How can I login to Pilot environment Accelus administration panel where I can view and manage registered cases?
Also, is it possible to add new / update results to specific ongoing screening case using Accelus?
world-checkscreeningscreening-api
4.5k 4 7 8
@m.matuzas,
Thank you for your query.
Your raised query is related to WC1 UI, request you to please raise your query via the MyRefinitiv support channel.
