We are using Pegasystems World Check one component for e-Screening via API, which is currently missing Enable Ongoing Screening feature. We are planning use the Enable Ongoing Screening API to implement the same. Can you please explain how is API works for each and every customer screening and best we can configure the same. Also please explain how the ONGOING SCREENING UPDATE FROM WORLD-CHECK ONE will be notified to us via which API and how it works. Please help me with detailed document. Thanks. Enable Ongoing Screening Enable OGS for a Case PUT /cases/{caseSystemId}/ongoingScreening
