What is the equivalent of get_data for RDP?
I am running some queries on vessel data in Refinitiv Workspace with codebook and I want to get the vessel data from the IMO numbers. However, I don't know what syntax to use from rdp. In Eikon, I would use get_data. If anyone know the equivalent in the rdp library would be appreciated.
rdp-apirefinitiv-data-platform
@milan_hedstrom you can use the get_data function as it has been incorporated into the latest RDP libraries. This gets the same data from ADC - there is a plan to recreate this whole experience on RDP natively but it is not there yet and thus a desktop license is still required to use these fields with all of the licensing limitations. Please see the examples in CodeBook App in the Eikon examples. If you need an RDP only solution you can look at using search API on RDP. Again there are RDP examples in CodeBook app.
import refinitiv.dataplatform.eikon as ek
ek.set_app_key('DEFAULT_CODE_BOOK_APP_KEY')
df, err = ek.get_data(['PEUP.PA','EUR=', 'JPY='], [ 'BID','ASK'])
df
I hope this can help.
6.7k 8 6 7
@milan_hedstrom please try the code below - you need to add the fields you want to the API call.
df, e = ek.get_data('9431214', ['TR.AssetLocationLatitude.date','TR.AssetLocationLatitude', 'TR.AssetLocationLongitude'], {'SDate':'0D', 'EDate':'-1AW'})
df
18k 21 12 20
Hi @milan_hedstrom
You can use the subpackage "eikon".
Please upgrade the RDP library
pip install refinitiv.dataplatform --upgrade
Then you can follow this code:
ek.set_app_key('xxxxxxxxxx')
df,e = ek.get_data(['RICs'],['FIELDs'])
I run into an error when I want to get_data for the IMO numbers. I should get the latitude and longitude numbers as a df.
