Started today. Here is the console output:
2020-09-03 14:13:42,198 pyeikon INFO Set App Key: None 2020-09-03 14:13:46,247 pyeikon INFO Response : 500 - {"code":500,"message":"Cannot find module \".\"","statusMessage":"Internal Server Error"} 2020-09-03 14:13:46,247 pyeikon INFO Port 9000 was retrieved from .portInUse file 2020-09-03 14:13:46,247 pyeikon INFO Try to handshake on url http://localhost:9000/api/handshake... 2020-09-03 14:13:46,258 pyeikon INFO Response : 400 - Handshake payload is invalid. 2020-09-03 14:13:46,259 pyeikon INFO Set Proxy port number to 9000 2020-09-03 14:13:50,287 pyeikon INFO Checking port 9000 response : 500 - {"code":500,"message":"Cannot find module \".\"","statusMessage":"Internal Server Error"} 2020-09-03 14:13:50,287 pyeikon INFO Port 9000 was retrieved from .portInUse file 2020-09-03 14:13:50,287 pyeikon INFO Try to handshake on url http://localhost:9000/api/handshake... 2020-09-03 14:13:50,529 pyeikon INFO Response : 500 - {"code":500,"message":"unable to get local issuer certificate","statusMessage":"Internal Server Error"} 2020-09-03 14:13:50,529 pyeikon INFO Application ID: *** 2020-09-03 14:13:50,529 pyeikon INFO Port 9000 on local proxy was detected 2020-09-03 14:13:50,530 pyeikon INFO Set timeout to 600 seconds 2020-09-03 14:13:50,726 pyeikon ERROR Error code 500 | Server Error: {"code":500,"message":"unable to get local issuer certificate","statusMessage":"Internal Server Error"}
http://localhost:9000/ping?all output:
{"port":9000,"mode":"eikon4","pid":12480,"hasSecure":true,"startedTime":"Thu Sep 03 2020 14:01:55 GMT+0300 (Russia TZ 2 Standard Time)","subApps":[{"path":"/heap"},{"path":"/ping"},{"path":"/sxs","data":{"hasSecure":true,"sxsApps":{}}},{"path":"/api"},{"path":"/sxs/v1/services/messenger"}]}
Already tried to clean Eikon cache and to reboot PC with no success.
I'm siting behind the corporate firewall.
Tried to run with the clean virtualenv and latest Eikon. It doesn't find the .portInUse (while 1.1.2 version finds them, see the log above):
Python 3.8.5 (tags/v3.8.5:580fbb0, Jul 20 2020, 15:57:54) [MSC v.1924 64 bit (AMD64)] on win32 Type "help", "copyright", "credits" or "license" for more information. >>> import eikon as ek >>> ek.__version__ '1.1.5'
2020-09-03 15:44:06,162 pyeikon INFO Timeout on checking port 9060 2020-09-03 15:44:06,163 pyeikon INFO Warning: file .portInUse was not found. Try to fallback to default port number. 2020-09-03 15:44:06,166 pyeikon INFO Try defaulting to port 9000... 2020-09-03 15:44:16,170 pyeikon INFO Timeout on checking port 9000 2020-09-03 15:44:16,171 pyeikon INFO Try defaulting to port 36036...
