Is there a way to get holiday calendar for markets (instrumen wise or general) using Java API?
We are looking to monitor a specified set of RICs if rates don't come in for a specified amount of time. However, we want to exclude holidays for this purpose. Is there a Java API to get holiday calendar for thios purpose? Any help would be appreciated
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apiricsjavamarket-holidaysholiday
@ahodlursuryakantha1
With the Realtime APIs, you can get holidays by subscribing to page records <HOLIDAYS>. This page contains RICs representing holidays of each country. For example, <TH/HOLIDAY> lists the public and exchange holidays for Thailand.
The text data is available in ROW80_1 to ROW80_25 fields. Therefore, the application needs to parse this text to retrieve the holidays.
For more information, please refer to the How to parse page-based data using Elektron SDK Java article. You can also directly contact the content team via MyRefinitiv for the formats of these holidays page records.
Thank you. I see the response is country based holidays. Is there a way to obtain FX currency based holidays directly rather than we having to maintain a map between currency and country?
To add, from my understanding, we can not get FX currency based holidays directly from Elektron Real-Time feed. The FX instruments are OTC traded and hence there are no holidays for FX markets. If it is a holiday in a particular country/region, there will be some contributions from other countries/regions. On common holidays you might notice less liquidity. Therefore you need to know a country for the currency and then use it to get the holidays page as Jirapongse said. You may also double-check with the content team about the RIC.
