Check access to API
Is there a way to check whether an account has access to the Python API? Or do all accounts come with the access to the Python API as long as Eikon desktop is installed locally on the machine?
18k 21 12 20
Hi @ap123
You can check at these 2 steps:
5. Locate "APIPROXY" and "Listening to port" in the log file. By default, the port is 9000.
7. Open http://localhost:9000/ping?all on a web browser. (Plese note that port 9000 is from step 5.) And make sure that you can locate {"path":"/api"}.
By the way, I tried lookup for your registered email address or your registered name on this forum but I could not locate your Eikon account.
Follow the link below to an article that among other things talks about how to check whether your Eikon account is entitled for Eikon Data APIs.
https://developers.refinitiv.com/article/eikon-data-apipython-troubleshooting-refinitiv
I had already tried that. Which bit of the article?
There's no section that specifies a quick way to check that the account has access to the API. Surely, the account wouldn't geneate an app key if there was no access?
If I can't locate it, does it mean the accouunt doesn't have access to the Python API?
Hi @ap123
Yes, I also sent an email to your registered email on this forum to ask about your Eikon account so I can look it up in the system.
Thanks.
