Python IDLE can't connect Eikon Data API, but jupyter notebook successfully connected
2020-08-28 17:00:38,208 P[13708] [MainThread 21556] Error: no proxy address identified.
Check if Eikon Desktop or Eikon API Proxy is running.
2020-08-28 17:00:38,221 P[13708] [MainThread 21556] Port number was not identified, cannot send any request
2020-08-28 17:00:38,232 P[13708] [MainThread 21556] Port number was not identified.
Traceback (most recent call last):
File "D:\Miniconda3\Lib\site-packages\eikon\111.py", line 5, in <module>
tr.set_app_key('cxxxxxxxxxxxxxxxxxxxxxxxxxxxxx0')
File "D:\Miniconda3\lib\site-packages\eikon\Profile.py", line 38, in set_app_key
get_profile().set_app_key(app_key)
File "D:\Miniconda3\lib\site-packages\eikon\Profile.py", line 233, in set_app_key
self.check_profile()
File "D:\Miniconda3\lib\site-packages\eikon\Profile.py", line 346, in check_profile
raise EikonError(-1, 'Port number was not identified. Check if Eikon Desktop or Eikon API Proxy is running.')
eikon.eikonError.EikonError: Error code -1 | Port number was not identified. Check if Eikon Desktop or Eikon API Proxy is running.
Hi @05032
I am not an Eikon expert - but just to eliminate the obvious - can you confirm the same version of the Eikon library is installed in the env used by Jupyter and the env used by Python IDLE?
You can check by outputting:
tr.__version__
Hi @05032
Please do not post your app key on a public forum.
I removed the app key from your screenshot and code.
11.5k 16 7 10
Hello @05032
I can replicate the same issue with Python version 3.8.3. The IDLE cannot connect to Eikon while Jupyter notebook that use the same version of Python can.
When I use Python version 3.7.x, the IDLE can connect to Eikon successfully, so could you please try with Python 3.7 version?
thank you, is work (python 3.7.7 & eikon 1.1.5)
6.7k 8 6 7
@05032 - I saw an issue with this problem using the Pycharm IDE - in this case I think dropping back to eikon library 1.1.2 resolved it. We are currently looking into these isolated issues and library 1.1.4/1.1.5. I hope this can help. Please let us know if this resolves things for the moment.
pip install eikon == 1.1.2
There will be others components problem,
thanks for your suggestion
4.3k 2 4 5
A new 1.1.6 version was released to fix HTTP connection issues with Python 3.8
As you set up your environment recently, I assume that your miniconda3_64 contains this version.
you can update eikon with "pip install --upgrade --no-cache-dir eikon" command line
