Error code 403 | Client Error:
I have been using the Eikon Data Api, but today I am getting this error, which I am not being able to solve:
command : data = ek.get_timeseries(rics,start_date = '2010-01-01', end_date = '2020-02-16', fields = 'Close')
error:
    179     ts_result = eikon.json_requests.send_json_request(TimeSeries_UDF_endpoint, payload, debug=debug)
    180
~\anaconda3\lib\site-packages\eikon\json_requests.py in send_json_request(entity, payload, debug)
    128                 return result
    129             else:
--> 130                 _raise_for_status(response)
    131     132         except requests_async.exceptions.ConnectionError as connectionError:
~\anaconda3\lib\site-packages\eikon\json_requests.py in _raise_for_status(response)
    251     if error_msg:
    252         logger.error('Error code {} | {}'.format(response.status_code, error_msg))
--> 253         raise EikonError(response.status_code, error_msg)
EikonError: Error code 403 | Client Error: <!DOCTYPE HTML> <html>
Regards,
Jagjit
4.1k 4 6 11
Hi @jagjit.singh
HTTP 403 meaning access to the requested resource is forbidden for some reason. For Refinitiv tools the most common causes are: no access for API feature, subscription has expired or account is not permissioned to access that particular data type.
