building ETA library for RedHat 7 64 bit
Building ESDK targeting at using on Red Hat 7 box. If I build the library on RedHat 6 box, will it still be able to be used in RedHat 7 ?
elektronrefinitiv-realtimeelektron-sdkrrteta-apielektron-transport-api
7.6k 15 6 9
@chonin.wu
According to the following doc
https://access.redhat.com/articles/rhel-abi-compatibility
It should works if you build it using the same GCC version and use shared lib rather than static.
I have a chance to run some ESDK sample app which builds form RHEL6 on RHE7 and it seems to works but I could not guarantee that it will work without any issue.
It could have some change on RHEL7 which might break the binary compatibility in a future release. Therefore, for the production app, I would suggest you build the app with the natively built libs on a specific platform instead.
