The truth value of a DataFrame is ambiguous.
Hello.
After reinstalling anaconda I started getting error in this code:
RICs=["SPY","TLT.O","IEF.O"]
timeseries=ek.get_timeseries(RICs,['CLOSE'],start_date='2020-08-10',end_date=RebalDate.strftime('2020-08-21'))
ValueError: The truth value of a DataFrame is ambiguous. Use a.empty, a.bool(), a.item(), a.any() or a.all().
PS: ek.get_data works fine
23k 22 9 14
Hello @m.semyanin and all,
According to case #09107507, the issue is fixed in the next version 1.1.6
@m.semyanin
I assume that you are using eikon==1.1.5. I got the same error when using 1.1.5.
eikon==1.1.5
You can downgrade to eikon==1.1.2 to avoid this issue.
eikon==1.1.2
18k 21 12 20
Hi @m.semyanin
I submitted a ticket no. 09107507 on your behalf.
The support team will be reaching out to you.
I tested the API call on 1.1.4(released on 18th Aug 2020) and 1.1.5(released on 20th Aug 2020) versions.
The problem only happens with the 1.1.5 version.
EK 1.1.4
EK 1.1.5
