Convert or map TICKER to RIC using the DSS API
Dear All, how are you?
Is possible to convert or map TICKER to primary RIC using the DSS API? I’m trying it using the function bellow and apparently the IdentifierType": "Ticker is not recognized.
My necessity is obtain a primary company RIC or the issuer RIC for a list of corporate bonds, since DSS doesn’t have an Issuer RIC field.
"ExtractionRequest": {
"@odata.type": "#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.TermsAndConditionsExtractionRequest",
"ContentFieldNames": [
"RIC", "ISIN", "Currency Code", "Exchange Code", "Exchange Code List", "Quote PermID"
"IdentifierList": {
"InstrumentIdentifiers": [
{ "Identifier": "AMZN", "IdentifierType": "Ticker" }
"ValidationOptions": {
"AllowHistoricalInstruments": true,
"AllowInactiveInstruments": true,
"AllowOpenAccessInstruments": false
"UseUserPreferencesForValidationOptions": false
Thanks in advance!
dss-rest-apidatascope-selectdssricssymbology
Hi @caio.zentil,
From my experience, IdentifierType=Ticker only works for /Search/InstrumentSearch. For all other API calls, it results in invalid instrument.
To be completely sure, please contact my.refinitiv.com to get in touch with a product content expert.
23k 22 9 14
Hello @caio.zentil,
Agree with @Gurpreet., InstrumentSearch can be useful to recognize Tickers.
Can try a two-step approach to see if it will work for your use case.
If you use InstrumentSearch request as the first step, to seed with Tickers and to request standard identifiers such as CUSIPs or ISINs,
You can choose to use TermsAndConditionsExtractionRequest as the second step, seeding it with CUSIPs or ISINs, and requesting "Primary Trading RIC"s or "Issuer PermID"s.
