Hi how are you!
Im having an issue when i try to launch my appi into jupyter,
EikonError Traceback (most recent call last) <ipython-input-5-1573465a72f8> in <module> 3 start_date = "2017-03-01", 4 end_date = "2020-06-12", ----> 5 interval="daily") ~\Anaconda3\lib\site-packages\eikon\time_series.py in get_timeseries(rics, fields, start_date, end_date, interval, count, calendar, corax, normalize, raw_output, debug) 176 raise ValueError(error_msg) 177 --> 178 ts_result = eikon.json_requests.send_json_request(TimeSeries_UDF_endpoint, payload, debug=debug) 179 180 # Catch all errors to raise a warning ~\Anaconda3\lib\site-packages\eikon\json_requests.py in send_json_request(entity, payload, debug) 128 return result 129 else: --> 130 _raise_for_status(response) 131 132 except requests_async.exceptions.ConnectionError as connectionError: ~\Anaconda3\lib\site-packages\eikon\json_requests.py in _raise_for_status(response) 251 if error_msg: 252 logger.error('Error code {} | {}'.format(response.status_code, error_msg)) --> 253 raise EikonError(response.status_code, error_msg) EikonError: Error code 503 | Server Error: API Proxy is not available
actually i dont know hoy to solve it!
could you please help me?
