How to generate case report in WC1 API?
Hi Team,
In the World Check One Web UI/platform, I can export the case summary report, as attached, in the Case Manager page. My question is whether I can generate such report via API. If yes, which endpoint I should use and how to configure the request body?
Thanks,
Leo
Report_5-8-2020_11.31.14.txt
world-checkworld-check-one
4.5k 4 7 8
@Lei.Wu,
Option of getting a PDF is only available via the UI. You may use -
API call- Fetch full case details,
Endpoint - GET /cases/{ {case-system-id}}
This endpoint will provide you most of the information of the case and create a PDF from your code using the response data.
Please let me know if you need further inputs.
Thanks, @Prabhjyot.Mandla!
What if I would like to export the summary in CSV format, rather than PDF? As shown in the below screenshot.
Can such CSV report be generated via API?
Thanks,
Leo
