Can any one help how to apply World Check one Screening as below Screen shot in My C# sample code As World Check one Api?
world-checkworld-check-oneapic#
4.5k 4 7 8
@m.arar,
Thank you for your query.
Via the API, you will find the types as categories. Use the endpoint - /cases/case-system-id/results to fetch the results of a case and search for categories of each match within the results.
 "categories": [
            "PEP"
Hope this helps.
Can You please give me an example of the request header,Response header and the body for /cases/case-system-id/results
4.5k 4 7 8
@m.arar,
The request and the reponse headers would look something like below -
There would not be a request body as the request type is GET. In the response you would receive the results for the specific case.
