Support for multiple nationalities
I'd like to ask if the following enhancement request was implemented or not:
https://community.developers.refinitiv.com/questions/13636/multiple-nationalities-as-secondary-parameter-for.html
Do you have any recommendations/best practises how to approach a situation when individual has multiple nationalities?
Thank you.
world-checkworld-check-oneapi
Hello @kamil.cisewski,
Could you please take a look at the follow-up client question?
4.5k 4 7 8
@lukas.kostial,
You can add up to 3 countries as Nationality and Country Location for an individual via API and UI. We will have to enable this functionality for your account to be able to use it.
Please let me know if you want this functionality to be enabled for your account.
Will the JSON payload format change once this feature is enabled or is it backwards compatible? Also could you please let me know (or point me to the documentation) how multiple nationalities should be sent via API ?
We would need to enable this feature in our pilot environment.
@lukas.kostial,
You can pass the request payload in the below format -
            "typeId": "SFCT_5",
            "value": "IND"
            "typeId": "SFCT_5",
            "value": "AUS"
            "typeId": "SFCT_5",
            "value": "BEL"
Can you please confirm if the account in pilot is - Gunvor SA?
Yes correct. Thank you.
4.5k 4 7 8
@lukas.kostial,
Thank you for your query.
Let me check this and get back to you.
