How to retrieve peers multiple mean/median for a list of companies at given date
I have a csv file containing the list of RICs and specific date for each RIC, like this:
I want to retrieve the mean and median multiple (P/E, EV/EBITDA) for each company at its specific date, and I've written the following code:
df=pd.read_csv(loc)
dataset=[]
df2=df["ticker"].values.tolist()
df3=df["date"].values.tolist()
for x in range(0,1):
keyword=df2[x]
date=df3[x]
data,err = ek.get_data('Peers("keyword")', ["TR.EVToEBITDA", "TR.PE"],{'SDate':date})
dataset.append(data)
the code is not working, especially the Peers("keyword") is treated as a string and Peers function doesn't work. I am wondering how can I modify my code to reach my goal.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonricspeers
@zxiaoah
The date format is incorrect. The correct format is 2014-01-09.
Therefore, the code should be:
df=pd.read_csv(loc)
dataset=[]
    keyword=df2[x]
    date=df3[x]
    print(keyword, date)
    data,err = ek.get_data('Peers({})'.format(keyword), ["TR.EVToEBITDA", "TR.PE"],{'SDate':date.replace('/','-')})
Thank you! It works perfectly.
Hi, I want to know if I can calculate the mean or median of the multiple of peers for a certain company within each loop? so that I can return a data frame with peer mean/median for each RIC.
@zxiaoah
I have run this code:
data,err = ek.get_data('Peers("1353.HK")', ["TR.EVToEBITDA","TR.PE"], {'SDate':'2014-01-09'})
data
The output is:
From the result, the Peers function works fine.
Thank you! but I have a list of over 600 stocks and manually changing instrument and date takes too much time. is there a way that I can use for loop or other to do that?
Hi @zxiaoah
https://www.w3schools.com/python/python_for_loops.asp
You can consider using loop in Python.
So you would have a list of RIC and Date in each loop and do the API call.
Thanks! I tried to use loop in my original code (shown above) but the "keyword" is always intrepreted as a string instead of the RIC I want. Could you give me some hints on how to modify my code?
